J.W. Winco, Inc. now offers GN 506.2 T-Nuts with Spring Washer, in metric sizes.
GN 506.2 T-nuts are designed for use with aluminum extrusions. They can be slid into position, i.e., inserted at any point along the slot. The spring washer prevents an unwanted movement of the nut in the slot, which is highly desirable on a bed with the T-slots in a vertical position. The unique feature of this design is that different slot heights can be bridged. One possible use of these T-nuts is to fit hinges to commercially available extrusion rails.
These RoHS compliant T-nuts are made of C45K, zinc plated, blue passivated steel. The spring washers are stainless steel, European Standard No. 1.4310 (American Standard Series 301).
J.W. Winco
www.jwwinco.com
Filed Under: Fastening + joining • locks • latches • pins, Screws • nuts • bolts, Washers • spacers
