Taiyo Yuden’s CM01S600 Common Mode Choke Coil
By Patrick Curran | November 19, 2009
Schaumburg, IL – Designed specifically for USB 3.0 applications, Taiyo Yuden’s new CM01S600 Common Mode Choke Coil is the first in the industry to deliver a 10 GHZ cut off frequency. A 25% higher cut off frequency improvement (compared to previous products) is achieved through the CM01S600’s use of an extremely precise wire-wound structure. A higher cut off frequency is especially necessary with the improvements in USB technology.
One of the most popular data-transfer interfaces in the world, USB is now available in a 3.0 version with speeds 10 times faster than the previous version (USB 2.0).  This new version increases the speed of data transfer between PCs and mass storage devices, including external hard-disk drives and high definition-compatible digital cameras.
Because the new 3.0 USB uses high-speed differential signal transmission, practical applications of it require that the resulting common mode noise be removed. Employing an extremely precise, wire-wound structure, the CM01S600 Common Choke Coil responds to this demand, and delivers a 25% higher cut-off frequency than previous products.
CM01S600 characteristics are shown below:
Ordering code
Common mode impedance
[Ω at 100MHz]
DC resistance
[Ω]
Rated current
[mA]
Rated
voltage [V]
Dielectric frequency
[MΩ]
Cut off
Frequency
[GHz]
Characteristic impedance
[Ω]
CM01S600
60 typ.
0.4 max.
300 max.
20 max.
100 min.
10.0 typ.
90 typ
“Typ.” Indicates typical values.
TAIYO YUDEN
www.t-yuden.com
Filed Under: CONNECTIVITY • fieldbuses • networks • gateways, ELECTRONICS • ELECTRICAL
