Target Pucks for TURCK DSU35 Valve Sensors
By Patrick Curran | June 11, 2009
Minneapolis, MN
–TURCK announces new target pucks for its DSU35 valve sensor series, which feature large targets to expedite and simplify sensing adjustments–ensuring highly accurate valve position data. DSU35 sensors monitor valve position via pneumatic rotary actuators, and then provide electronic feedback indicating an open or closed position. A fully adjustable target puck is placed over the actuator stem and features interlocking teeth for accurate positioning, as well as providing vibration resistance.
In addition to the target puck, TURCK is offering new dome and cover accessories for the DSU35 valve sensor series. A dome may be placed over the puck to provide highly visible indication of the valve’s current position. Domes are available in two color schemes: red and green or yellow and black. An optional cover is also available, which aids in protecting the puck from debris or spills in the application environment.
TURCK
www.turck.us
Filed Under: Sensors (position + other), Test + measurement • test equipment, Valves
mti
MTI
moog
