TB Wood’s Roto-Cam mechanical clutch
By Mike Santora | February 18, 2021
tbw-roto-camTB Wood’s easily installed Roto-Cam® mechanical clutch completely eliminates external, separately mounted fulcrums, yokes, levers, or trunnions and permits a simple, clean compact control system for direct or remote — manual or powered — actuation. Roto-Cam provides smooth easy engagement typical of a spring-loaded clutch plus a positive, over-center “lock-in”. The clutch can be “inched” or “Jogged” for complete operator control.
TB Wood’s
www.tbwoods.com
Filed Under: Coupling Tips
Tagged With: tbwoods
PTDA onProduct Information Exchange
PTDA Transmissions: Lessons from the Pandemic past can shape the future
Shaft collars and couplings feature wide choice of standard bores
Torque transducers and test machinery use CD couplings from Zero-Max
