North American distributor Sager Electronics is now stocking TDK-Lambda’s PFH500F Conduction Cooled 500-W ac/dc Power Modules.
The PFH500F Series is a high density and high efficiency ac/dc power module that comes
in a compact 4×2.4-in brick footprint. It’s rated at 500 W and operates from 85 to 265 Vac input. The series is suitable for conduction cooling and can operate from -40 to 100 °C baseplate. It comes with Read/Write programming and communication through a PMBus interface with optional droop mode current share for simplified parallel operation.
The PFH500F series is ideal for a wide variety of industrial, test, communications, COTS and commercial applications.
TDK-Lambda’s PFH500F Conduction Cooled 500-W ac/dc Power Modules are in stock at Sager Electronics, 19 Leona Drive, Middleborough, MA 02346, https://power.sager.com/manufacturers/tdk-lambda/tdk-lambda-pfh500f-conduction-cooled-500w-ac-dc-power-modules/default.aspx
Filed Under: Power supplies, MOTION CONTROL
