    • Subscribe!
Reed switches designed for industrial liquid-level monitoring
By Lee Teschler | November 30, 2020
Liquid Level Switches use reed-switch technology, delivering an extended product life of 10M+ cycles, high electrical load capacity, low contact resistance and UL approvals. In addition, TE’s Liquid Level Switches are offered in a wide range of standard and custom options providing exceptional price-to-performance. Liquid level switches can be found in applications such as HVAC, wastewater systems, chemical and petrochemicals, and in the food and beverage industry.
“To compete in today’s ever-increasing competitive market, TE has developed liquid-level-switchesLiquid Level Switches,” said Gaddiel Garcia, product manager, Position Sensors at TE Connectivity. “Liquid Level Switches require no power source to facilitate switching action giving our customers a flexible, yet reliable solution for industrial applications requiring liquid level monitoring within a contained space.”
Liquid Level Switches can be arranged to have normally closed or normally open switch indication with the rise or fall of liquid, and they can be horizontally or vertically oriented. All housings have at least IP65 enclosure rating and are available in different materials such as polypropylene, polyamide, polyvinylidene fluoride (PVDF), PVC, brass and stainless steel. The electrical sealing of the level switches allows no direct contact with liquids, which could cause corrosion issues. Liquid Level Switches can be used in high temperature environments and no EMC testing is required.
TE Connectivity, MUehlenstrasse 26, Schaffhausen 8200, Switzerland, 41 52 633 66 61, http://www.te.com/sensors
You may also like:
  • Look at what micro 3D printing can make
  • What is a Molecular Property Spectrometer sensor?
  • What is photoacoustic spectroscopy (PAS)?
  • What are the evolving semiconductor technologies for modern telehealth applications?
  • What is a Sensor HAT?
Filed Under: TECHNOLOGIES + PRODUCTS, Sensor Tips, Switches
Tagged With: TEConnectivity
omron-d2gw
Heilind Electronics adds Omron D2GW Sealed Ultra Subminiature Switch to its portfolio
PX AND PA Series foot switches
The fundamentals of electromechanical on/off switches
HoverTap Lift from NZ Technologies takes elevator call buttons to new highs
    • Subscribe!
