    • Subscribe!
Techno, Inc. CNC Routers introduces the Techno Universal Knife System
By Patrick Curran | March 26, 2010
New Hyde Park, NY – Techno, Inc. CNC Routers introduces the Techno Universal Knife System, all in one universal tool that uses one main drive capable of processing multiple applications through interchangeable heads. Using a common rotary drive, the Techno Universal Knife System can change between the Oscillating Knife, Tangential Drag Knife, Spring Loaded Pen, Vinyl Drag Cutter or Creasing Wheel Kit when needed.
Universal_Knife_System
“Our Universal Knife System was designed to target various industries that would benefit from an interchangeable tool, says Roy Valentine, CNC Routers Sales Manager. Whether the company is a Sign or Point of Purchase manufacturer that needs to cut graphic art sheets printed on a wide format flat bed printer, HVAC manufacturer that needs to cut acoustic liners or a packaging manufacturer that needs to cut and crease corrugated cartons, this one system is the right product.”
In addition to the interchangeable heads mentioned above, the Techno Universal Knife System can be combined with the Techno Vision (digital image verification package) to provide Sign and Graphics customers a complete and easy-to-use digital finishing solution. System functions allow the operator to load material on any Techno CNC Router, select the image for routing and press “Start”. The machine will then verify the linear and rotational distortion and proceed in routing the pattern of the desired image before your eyes.
www.techno-isel.com/cnc_routers/universal_knife.htm
Filed Under: Factory automation, Automation components, Machine tool industry + subtractive manufacturing
Dual high-temperature Cabinet Cooler systems for large enclosures
    • Subscribe!
