Techno’s New Pro Series 4896 Model CNC Router
By Dave Miyares | June 4, 2009
New Hyde Park, NY —Techno, Inc. CNC Routers releases the first production run of the Model 4896 Pro Series. Introduced earlier this year, the Pro Series was designed to meet the high demands of panel process manufacturing; now Techno expects this new heavy weight (3050 lbs) 4896 model to be the most popular, with its 4 ft x 8 ft process area and very attractive base price ($30,000).
Techno’s Engineers utilized innovative software to provide mathematical testing of designs called Finite Element Analysis (FEA) which provided load characteristic analyses of the machines components ultimately determining whether material improvements were required to build a better machine, or if different building strategies would be viable to reduce the cost without sacrificing quality.
The heavy-duty, welded and stress-relieved base is a perfect foundation for Techno’s precision drive system. Equipped with a moving gantry that requires less valuable space, precision ball screw drives on all three axes, THK rails/bearings, and high-speed closed-loop servomotors and drives this new design ensures minimal maintenance and machine longevity. The Pro Series can also be equipped with a variety of single- to multi-spindle setups for high volume part production, multi-zone vacuum table, reverse engineering lasers, 4th axis rotary tables and more! Every machine also receives Techno’s Windows-based CNC Servo G-Code Interface, the fully comprehensive CNC program which includes unique high-end features that are both easy to use and operate.
Techno Inc
www.technocnc.com
Filed Under: Machine tools + subtractive manufacturing, LINEAR MOTION, Motion control • motor controls
