    • On the Floor
Teflon composite bearings now available as twin pillow block linear rail assembly
By Mike Santora | February 28, 2022
LM76-Minuteman Series Twin Pillow Block Linear Rail Assembly 4x5x300Save time and energy by ordering one or more Minuteman TM M-SRBT Twin Pillow Block Linear Rail Assemblies from LM76. Recognized by engineers, machine builders, and retrofitters, the Minuteman TM Series of Teflon composite bearings from LM76 are suitable for applications that involve linear, rotary, and/or oscillating motion. The self-lubricating Minuteman Series composite bearings can handle 10 times the load, has a very low coefficient of friction, dampen vibrations, tolerates shock, and are lower in cost than conventional linear ball bearings. These composite bearings can be submerged, washed down with water, high-pressure steam, or chemicals, and can operate in harsh, abrasive, and contaminated
environments.
Designers specifying a Minuteman TM M-SRBT Twin Pillow Block Linear Rail Assemblies can select from seven different shaft sizes from 0.500-in. to 2.000-in. of either RC60 case hardened steel or 303 stainless steel rail guides in lengths to 12-ft.
As composite bearings are in 100% contact with the shaft there is no place for contaminates to collect and these bearings will not score aluminum shafting.
LM76 manufacturers a broad variety of bearings and shafting that can easily be integrated into new and existing applications. The bearing options include Self-lubricating FDA & USDA-compliant Teflon composite bearings in a 304 stainless steel shell, and lower-cost bearings with a ceramic-coated shell and FDA & USDA compliant liner. Bearings are available in closed
and open configurations, and are drop-in replacements for all-inch-sized linear ball bearings.
Shafting options include Solid and hollow Class L 304 stainless steel, and ceramic-coated aluminum shafts in lengths to 12-ft. FDA & USDA compliant, shafting features: Excellent corrosion and chemical resistance, custom machining to print, pre-drilling, and assembly.
LM76
www.lm76.com
Filed Under: Bearing Tips
Tagged With: lm76
    • On the Floor
