Telerace Rails for simpler, higher-performing automated systems
By Mike Santora | January 13, 2022
TLQ scontornataRollon has upgraded its Telerace family of linear rails to help designers simplify projects and enhance the efficiency of automated systems. Two Telerace families of cold-drawn steel rails now feature induction hardened and ground raceways along with double-row ball bearings for greater load handling capability, longer life, and reduced maintenance requirements.
The newly enhanced rail versions carry a “Plus” designation, provide full extension, and offer distinct features: -TLQ version. Adjustable sliders allow users to set the stroke length/load capacity ratio by up to ±20 percent -TLR version. This unit manages misalignment errors of up to ±2.7 degrees and compensates for the dimensional difference between the structure and a drawer with a tolerance of up to 0.5 millimeters.
Six Telerace versions are available in total, and customers can choose versions with one or two rows of ball bearings as well as different sizes and materials. These systems are well-suited for vertical use and less sensitive to high dynamics and shifting working cycles that are prevalent in automated machinery.
Additional advantages include:
-Reliable vertical and variable strokes. Since Telerace does not have a ball cage, automated vertical and variable strokes are possible.
-Low opening and closing force. Sturdy profiles minimize deflection, and ground raceways ensure smooth, silent movement with low friction.
-Reliability in dirty environments. Large rolling elements make Telerace more tolerant to dirt and debris. And, end-stoppers include wipers with slow-release felts for clean and constantly lubricated raceways.
-Long lifetime. Induction hardened raceways and Rollon-Nox hardening treatments ensure long life. -Corrosion resistance. Surface treatments make Telerace reliable in harsh environments.
Rollon
www.rollon.com
Filed Under: Linear motion • slides
Tagged With: rollon
LM76-SPEED DEMON EL300 4x5x300
LM76 SPEED DEMON EL300 for high speed, low friction, smooth linear motion
Stainless steel linear guide rail systems
LWLF2_FAM
IKO’s New LWLF2 Miniature Linear Guides
igus introduces self-lubricating toothed belt axis designed for clean use in food technology
