TEN 50 Highest Power Density 50 Watt DC/DC Converter
By Natasha Townsend | June 13, 2012
The TEN 50 Series of high performance 50 W dc/dc converters from Power Sources Unlimited, Inc. converts into a 1in. x 2 in. x 0.4 in. industry standard package size.
This series models feature a high efficiency of up to 92%. The low thermal dissipation and the use of highest-grade components allow for an operating temperature range of –40°C to +85°C. Forced air-cooling is not required up to 55°C. With an optional heat sink, this temperature can be increased. Unit requires no minimum load to obtain accurate output regulation. The TEN 50 Series comes standard with remote on/off function as well as an adjustable output voltage range of ±10%. Along with superb standard features, these converters are the ideal solution for space critical high performance applications.
Additional features include 2:1 input range, 1500VDC I/O isolation voltage, metal case with insulated base plate, cUL/UL 60950-1, and IEC/EN 60501-1 safety standards approvals.
PSUI
www.psui.com
Power Supply Tips
Filed Under: Power Electronic Tips
schurter
Compact power entry module has side flange mounting option
ABSOPULSE
Three-phase power supplies with active PFC handle 5-kW industrial applications
Sager Electronics to carry SL Power’s 300-W single-output power supplies
wuerth catalog
Catalog covers certified components for automotive electronics
