Test interface fixture for surface mount single and dual row connectors
By Mary Gannon | August 20, 2019
CAMI Research Inc. has released a test interface board for surface mount single and dual row connectors with 0.05 in. (1.27 mm) pitch and up to 34 and 68 pins respectively. Rated to 500 Vac/dc, the CB55 may be used on all CableEye models.
CAMI CableEye high-density cable test fixtureCB55, sold without connectors, has surface mount pads for four dual row connectors at 0.05 in. (1.27 mm) pin pitch with up to 68 pins: two each of different row separations. A single row connector can be soldered to any dual row location. The footprints are suitable for many connectors including those by 3M and ERNI.
CAMI offers the CableEye suite of products complete with accessories – including auto-detected, plug-in connector boards for fast, convenient set-up and testing of standard cables. There is an extensive and growing stock library of these test fixture boards – several of which are populated with families of connectors, such as the video market’s CB16A for BNC, SMB, SMA, and N connectors. Many boards are sold unconnectorized, a high proportion of which are configured for specific connectors, such as the CB41 through CB44 for Micro D connectors. When pre-populated and pre-configured boards are used, the tester GUI automatically displays a graphic of the connectors and wiring under test. The tester can be readily programmed to do the same for custom boards and fixtures. These boards are designed to fit all CableEye testers.
The CB55, sold without connectors, has surface mount pads for four dual row connectors at 0.05 in. (1.27 mm) pin pitch with up to 68 pins: two each of different row separations. A single row connector can be soldered to any dual row location. The footprints are suitable for many connectors including those by 3M and ERNI. As with all standard CB boards, connectors under test are instantly, automatically detected and rendered on the screen together with the wiring.
Sold as a set of two boards, each test board may be paired with other CableEye adapter boards to accommodate any combination of connectors. An incredibly versatile test system, CableEye testers are expandable to accommodate large and complex harnesses, and users can connect, and configure them in numerous ways — set up an array of QuickMount housings fitted connector boards, plug custom interface cables directly into any of the 64 pin headers on the control and expansion modules, or use a test interface panel, perhaps on a rack-mounted system. Not just a tester, CableEye is a complete cable management system offering features not available on any other cable test equipment, and may be used to test unlimited types of connectors.
CAMI Research
www.camiresearch.com
Filed Under: Connectors (electrical) • crimp technologies
Tagged With: camiresearch
molex-versablade-300x300
Heilind Electronics now offering Molex VersaBlade Wire-to-Wire Connector System
bel-stewart-m12xcode-connector
Stewart Connector M12 X-Code PCB mount connectors
Heilind-electronics-product-image
Heilind Electronics now offering Molex PowerPlane BusBar Power Connectors
Harting Technology Group heads for a climate-neutral future with record investment
