Norstat now offers the 180 Series Beacon, a multi-color signal beacon that can also be equipped with an audible signaling device for additional effectiveness.
The 180 Series Beacon is a basic signaling lamp that is available as a multi-color signaling beacon as well as in Tri-Color versions of Green, Yellow and Red or Blue, Yellow and Red. These signal Beacons can also be equipped with audible devices for additional signaling effectiveness. The 180 Series utilizes high luminosity LED RGB lighting with flashing or continuous light and continuous or pulsed audible tones. The 180 Series also utilizes double lenses with triangular rifling horizontally and vertically for true 360° diffusion.
Housing is polycarbonate with a diameter of 60 mm and offers easy and practical installation. Connections are via screw clamp, M12 connector (5-8 pole), 5 pole cable or cable with M12 5 pole connector. 180 Series Beacons carry a protection rating of IP 65 and are also resistant to vibration.
Norstat
Filed Under: Lights • signal lamps • indicators
