Muncie Power Products assists the truck equipment and other fluid power markets with its TG Series power take-off.
The TG Series is available with 10 speed ratios, 19 shift types, 19 output shaft options and 78 input gears for all popular transmissions. The double gear type power take-off can be configured to meet the speed, torque and horsepower requirements of most applications.
Muncie Power Products is now the sole provider of an electric/hydraulic shift option. This TG Series’ option eliminates the need for shift cables.
A die-cast aluminum housing reduces weight and noise with superior heat dissipation. For simplified installation and flexibility for an easier repair, the TG Series has a 6 or 8 bolt housing and modular design.
Its constant mesh input gear isolates the transmission from engagement errors. And a compact size minimizes mounting interference with rotatable hydraulic flanges for maximum pump clearance.
www.munciepower.com/tgseries
Filed Under: Cables + cable management, Hydraulic equipment + components
