  • Articles
  • 3D CAD Models
    • 2020 Winners
    • 2019 Winners
    • 2020 LEAP Awards
    • DIGITAL ISSUES
      • EE World Digital Issues
    • 2020 LEAP Awards
    • Motion Design Guide Library
    • Suppliers
  • COVID-19
The C-Flex Lattice Servo and the C-Flex Lattice
By Mike Santora | January 13, 2021
MetricLatticeCoupling-1100x302
Couplings are revolutionary, patented designs which combine the best characteristics of bellows, disc, and beam couplings into a single integrated component. Designed to couple two rotating shafts together, they can accommodate misalignments far greater than other couplings on the market, while transmitting high torque loads with zero backlash.
Their construction provides for a low moment of inertia and minimal impact upon system dynamics. A large through-hole allows for smaller coupling utilization for fitting larger shafts and the fact that they can be disassembled prior to installation, makes them ideal for retrofit applications.
Constructed using high strength hardened stainless steel flexures, the couplings require no maintenance, providing years of trouble-free life, even in contaminated environments. Directionally independent, they can provide the same torsional rigidity and offset capability regardless of the rotation direction. The use of C-Flex Couplings in mechanical systems to connect rotating shafts will result in lower energy usage and bearing failure since less stress is placed upon bearings. Misalignment forces on the bearings of a rotating system generates heat which is wasted energy. The use of C-flex couplings will minimize these misalignment forces and result in a more energy-efficient system. C-Flex Super Plastic Couplings will stabilize high precision systems by dampening transient torque variations.
C-Flex Bearing Company
c-flex.com
MOTION DESIGN GUIDES
  • Configuration Management: Configuration Integrity IS A Core Driver for Business Success
  • How to Choose a Linear Actuator
  • Create your perfect machine with Advanced Engineering
  • How a ME/EE turned passion for design into his own bike company
  • Everyone Can Save on Cable Costs. Here’s How
  • How and Why You Should Use a Wave Spring for Bearing Preload
Tweets by @DesignWorld
  • Articles
  • 3D CAD Models
    • 2020 Winners
    • 2019 Winners
    • 2020 LEAP Awards
    • DIGITAL ISSUES
    • 2020 LEAP Awards
    • Suppliers
  • COVID-19
