The Duplex Screw: An easy-to-use reusable fastener
By Michelle Froese | October 14, 2020
The Duplex Screw is a strong reusable double-headed hex-head screw that is easy to install, remove, and use again.
Watch how to properly use Duplex Screw in this video.
Available at Advance Components, a distributor of specialty fastening products, Duplex Screws easily hold project together — and are easily removed when necessary. Compared to drywall screws or duplex nails, the Duplex Screw can be used multiple times with less effort.
In fact, studies show that it can be installed as fast as 45 screws per minute compared to duplex nails at 24 per minute. Simply install with a standard 1/4-inch impact driver or Phillips screw driver. The installation and removal is so easy that it reduces the risk of injury to thumbs, fingers and wrists.
The orange-topped hex-head on the screw also makes it easy to install and find.
Features
  • Saves time and money
  • Multiple re-use possible
  • Less injury, and easy to install and remove
  • Secure bit, snug fitting, and no slipping
  • Easy to find bright orange head
  • Sizes: 1-1/4″, 1-5/8″,1-3/4″, and 2-3/4″
  • Ships in 5, 25 and 50-pound boxes
Duplex Screws are manufactured by RemoveRite, Inc., and are distributed exclusively by Advance Components. Learn more here.
Tagged With: advancecomponents
