Wolfspeed’s CMPA2735015S is a gallium-nitride (GaN) HEMT-based monolithic microwave integrated circuit (MMIC). GaN has superior properties compared to silicon or gallium arsenide, including higher breakdown voltage, higher saturated electron drift velocity and higher thermal conductivity. GaN HEMTs also offer greater power density and wider bandwidths compared to Si and GaAs transistors. This MMIC contains a two-stage reactively matched amplifier design approach enabling very wide bandwidths to be achieved. This MMIC enables extremely wide bandwidths to be achieved in a 5×5 mm Surface Mount QFNL-32 package.
| Peak Output Power | 15 W | |
| Application | L-Band / S-Band / X-Band / C-Band / Ku-Band | |
| Typical Power Added Efficiency PAE | 50% | |
| Typical Power (PSAT) | 15 W | |
| Operating Voltage | 50 V | |
| Frequency | 2.7 – 3.5 GHz | |
| Package Type | Surface Mount QFNL-32 | |
| Small Signal Gain | 32 dB | |
| Size | 5×5 mm | |
To learn more click here.
