The flattest draw-wire encoder on the market
By Mike Santora | July 7, 2020
z4538_Seilzuggeber_B75In the field of linear measuring technology, Kübler has further developed a draw-wire encoder that has already proven its worth. The B75 draw-wire encoder, which is known not only for its robust construction but also for its flat design, is now also available with a redundant analogue sensor (4 … 20 mA or potentiometer). New safety concepts in mobile automation can thus be implemented with this variant or with redundant sensors.
The cable pull mechanism can be combined with various sensors. Thus, analog, incremental, and fieldbus interfaces are freely selectable. The alignment of the connection technology, for example of the flange-mounted encoder, can be optimally aligned depending on the application or space conditions. In addition, the pull-out direction of the cable pull can be flexibly selected in 90° steps. Kübler has thought of something special for outdoor use where sensors are exposed to adverse conditions. Closable ventilation and water drain holes prevent any formation of ice at sub-zero temperatures, as liquids can escape.
The draw-wire encoder can be used for applications up to 3 m and measures with a linearity of max. ±0.35 % and a speed of 0.8 m/s. The linear sensor can be used for applications up to 3 m.
The B75 draw-wire encoder is already used today in mobile machines, working and rescue platforms, driverless transport systems, and in general automation.
Kübler
www.kuebler.com/draw-wire-encoders
Filed Under: Encoders • absolute
Tagged With: kubler
50 years of bit parallel encoders from POSITAL
z4636-F5858-Profinet-enc-std-srgb-web
Sendix F5858 industrial ethernet encoders with PROFINET IO interface
US Digital releases magnetic encoder in incremental and absolute configurations
z4536-Sendix-F58-Profinet
New generation industrial ethernet encoders for real-time applications
