    • Subscribe!
The ILPS-18S Series Spring Loaded LVIT Linear Position Sensor economical high-performance gauging probe
By Editor Design World | April 5, 2018
Harold G. Schaevitz Industries LLC (HGSI) has expanded its sensor product offering by adding a line of ILPS-18S Series Spring Loaded Inductive Linear Position Sensors using LVIT Technology.  The ILPS-18S was designed as an economical solution for dimensional gauging and position measurements in commercial, industrial, and military applications.  With their compact design, long service life, and excellent stroke-to-length ratio, ILPS-18S sensors are ideal for test stands, test laboratories, automated assembly machines, processing & packaging equipment, robotics, and automotive test applications.
ILPS-18S Features:
  • Measuring ranges from 13 to 100 mm (0.5 to 4 inches)
  • Excellent stroke-to-length ratio
  • Lower cost replacement for spring loaded LVITs
  • Long service life, rated to over 100 million cycles
  • 19 mm (0.75 inch) diameter threaded aluminum housing sealed to IP-67
  • Axial termination with either M12 connector or integral cable
The ILPS-18S series offer a choice of four analog outputs and all include HGSI’s proprietary SenSet™ field recalibration feature.
www.alliancesensors.com
Filed Under: Sensor Tips
Tagged With: alliancesensors, hgsi
Endress+Hauser launches new sensors and holder assembly
What metrics can bioelectrical impedance analysis provide? Pt 2.
What is 3D scanning?
    • Subscribe!
