Theorem’s product rebranding
By Frank Tobe | December 22, 2015
In an effort to simplify and streamline the choices for CAD to CAD, CAD to STEP, CAD to Visualization or CAD to Publishing, Theorem Solutions has rebranded its product portfolio.
The brands are now defined as follows:
CADverter
The CADverter brand has a product focus specifically on the direct translation of 3D data to or from an alternate mechanical CAD or Standards Based format.
CADverter products translate assembly structure, geometry, attributes and, where available, 3D Product Manufacturing Information (PMI) (FTA) (GD&T) and Metadata, between the world’s leading mechanical CAD/CAM systems.
These products help solve the issue of working with and sharing incompatible data formats.
Multi-CAD
When developing large and complex products, such as cars or airplanes, designers may need to use multiple CAD systems. Multi-CAD products support the introduction of assembly structure, geometry, attributes, 3D Product Manufacturing Information (PMI) (FTA) (GD&T) and Metadata from foreign CAD and Visualization data with additional support for the processing of Model Based Definition (MBD) information from native CAD.
Publish 3D
The Publish 3D suite helps create documents with 3D content directly from the native source CAD or JT data. The products focus specifically on the publishing of 3D mechanical CAD and Visualization data into an interactive document format. It supports the translation of assembly structure, geometry, attributes, 3D Product Manufacturing Information (PMI) (FTA) (GD&T) and Metadata from leading mechanical CAD/CAM systems, and in doing so, facilitates Model Based Definition (MBD) processes.
Visualize 3D
The Visualize 3D suite of products directly translate 3D data from mechanical CAD systems for the purpose of Visualization.
These products create visualization data for users of digital mockup, virtual reality or desktop applications. They support the lightweight data formats: 3DXML, Creo View and JT. They also support the translation of assembly structure, geometry, attributes, 3D Product Manufacturing Information (PMI) (FTA) (GD&T) and Metadata between leading mechanical CAD/CAM systems.
Process Automation
The Process Automation programs manage and automate the process of creating, sharing and exchanging data with suppliers and customers to aid the collaboration process. These programs manage high volumes of data transfer and translation to and from varying formats for different design disciplines or document creation, streamlining workflows and eliminating repetitive manual work while enforcing consistency.
This suite of products allows users to automate, schedule, monitor and control repetitive translation and document creation.
It is Theorem’s belief that there is no one single solution for collaboration. The right solution is set by the individual use case and not by product. No one product can answer all data exchange issues.
Theorem Solutions
www.theorem.com
Filed Under: 3D CAD, TECHNOLOGIES + PRODUCTS, Virtual reality
Tagged With: theoremsolutions
55416_commModule_APL_300dpi_cmyk
Softing introduces a hardware module for implementing Ethernet-APL field devices.
IO-Link Smart Field I/O System from AutomationDirect
50 years of bit parallel encoders from POSITAL
EXAIR 3D model and CAD Library has more than 70 extensions
