Thermal Adhesive for Optimized Heat Dissipation
By Patrick Curran | August 5, 2009
Hackensack, NJ – Master Bond's EP30BN is a two part boron nitride epoxy adhesive offering improved thermal management of heat generating components. EP30BN is a medium viscosity epoxy system with good flow characteristics, making it an ideal thermally conductive adhesive for bonding, sealing and potting applications. Featuring remarkably high thermal conductivity and excellent electrical insulation properties, the thermal epoxy is designed to optimize heat dissipation of aerospace, defense and microelectronic assemblies with minimal weight penalty. It is formulated to cure at room temperature or more rapidly at elevated temperatures to a tough, thermoset, dimensionally stable plastic. Attractive mechanical strength properties and outstanding chemical resistance are maintained over the wide temperature range of -60°F to 300°F -50°C to 150°C).
Master Bond EP30BN has excellent electrical insulation properties with a volume resistivity in excess of 1014 ohm cm and an impressive thermal conductivity of 24 BTU/hr/ft2/°F/in. Given a specific gravity of only 1.1 it greatly excels the performance characteristics of competitive thermal management materials. EP30BN two part thermally conductive epoxy is an attractive solution for applications requiring effective heat management for high tech devices with weight sensitive components together with electrical insulation and environmental protection properties.
Master Bond
www.masterbond.com
Filed Under: Adhesives • epoxies, Materials • advanced
