Thermocouple Data Logger from Omega
By Design World Staff | October 27, 2008
The OM-EL-USB-TC data logger measures and stores over 32,000 temperature readings from either type J, type K or type T thermocouple which plugs into a miniature female thermocouple receptacle at the base of the unit. The user can easily set up the initial data logging parameters including thermocouple type, logging rate, start-time, high/low alarm settings, logging mode and desired temperature units (Celsius or Fahrenheit) and also download the stored data by plugging the module straight into a PC’s USB port and running the easy-to-use Windows software.
Downloaded data can then be graphed, printed and exported to other applications such as Excel. The data logger is supplied complete with a long-life lithium battery. Data logger status is indicated by flashing red, green, and orange LEDs. This product is perfect for chemical, water, and pharmaceutical industries.
www.omega.com
Filed Under: Data acquisition + DAQ modules, Sensors (temperature), ELECTRONICS • ELECTRICAL
Tagged With: Omega Engineering
