Crescent Tools‘ new Wood Drilling program offers a full line of drilling products designed for speed, precision, and durability on the job site. Made with the user in mind, it features a range of wood drill bits — including multiple sizes and lengths in high-speed spade and auger bits, flat spade bits, solid and ship augers, installation, and self-feed drill bits.
Learn more about Crescent Tools line-up of drill bits in this video.
The new drill bits are embedded with an optimal flute design and tripled-sharpened high-speed steel for reliability and efficiency.
The design of the High-Speed Auger Bit lets it strike and pull through nail-embedded wood at a rapid speed for a precise, clean cut. With a tri-flute design, this bit will cut through 20x faster than competitive standard flat paddle bits. It also features a 1/4″ quick-release hex shank, and a modified impact zone that increases the life span by eight times, allowing for faster chip removal and more cuts per charge.
The Screw Point Paddle Bit was designed with technology for quicker engagement in materials, enabling the bit to pull through wood at rapid speed to make precise, clean holes. Users can complete jobs quicker due to the modified impact zone that provides 15x cutting speeds, while maintaining control. This bit can burst through problematic nails with the refined spurs and the contoured paddle bit to remove chips and prevent hole clogging.
