VENTURA, CALIFORNIA – ThinGap LLC announces the ironless core TGB2020 brush motor, which delivers up to 440 watts and 425 oz-in. peak shaft torque. The high continuous power capacity of this small diameter motor makes it ideal for driving low profile vehicles, power tools, and any load that requires a small cross section. Additionally, the TGB2020‚’s provides high acceleration coupled with continuous high power.
In blower and thruster applications, the motor provides a low frontal area minimizing drag within air or liquid movers. The sealed version of the motor provides high efficiency for longer battery life and is well-suited for undersea thrusters. For applications with space constraints, where efficiency and drag are important, the TGB2020 motor provides an excellent solution. Other important characteristics of the motor include low inertia and high bandwidth.
The TGB2020 is only 2-inches in diameter by 5.3-inches long. It features rare earths magnets and a high copper density, ironless coil, which provides excellent heat dissipation, low losses, zero cogging, low inertia, and superior power to weight and size ratios. The motor allows a maximum efficiency of 90%. Brush life is excellent because of the low inductance of the ironless coil. Brush-eroding arcing is minimal at very high current and speed. Low winding resistance makes the motor ideal for battery-driven applications where resistance limits power output from the battery.
www.thingap.com
Filed Under: Motion control • motor controls, Motors • dc
