This epoxy has a special color-changing feature
By Michelle Froese | March 15, 2024
Click here to request a technical data sheet.
Master Bond‘s UV15RCL is a low-viscosity, cationic-type UV curing system with a special color-changing feature. The originally red material changes to clear once exposed to UV light, indicating that there’s UV light access across the adhesive material.
Although this change in color from red to clear does not indicate a full cure it does confirm that the UV light has reached the polymer. By giving immediate visual feedback UV15RCL offers processing and handling advantages over conventional systems.
Curing under UV light typically takes 30 to 60 seconds with a broad-spectrum UV lamp emitting light with a wavelength range between 320 to 365 nm. The minimum energy required is 20 to 40 milliwatts per cm2.
UV15RCL features a high glass transition temperature (Tg) of 90° to 95° C. However, when post-cured for one to two hours at 125° C, the Tg can increase to 125° to 130° C. It has a service temperature range from -80° to +350° F.
This non-solvent based system cures tack free and has an extremely low viscosity of 115 to 350 cps, making it ideal for spin coating. It’s not oxygen inhibited and provides light transmission properties and good optical clarity, with a refractive index of 1.517. Also, it’s an excellent electrical insulator with a volume resistivity exceeding 1014 ohm-cm.
UV15RCL is suitable for bonding and sealing applications as it adheres well to metals, glass, ceramic,s and many plastics — including acrylics and polycarbonates. It is available in a range of packaging options, including syringes, 1/2-pint, pint, quart, and gallon containers.
Filed Under: Adhesives • epoxies
Tagged With: masterbond
