This fastener adds security and aesthetics to any application
By Michelle Froese | August 15, 2022
Check out the 2-Hole fastener installation video here.
To add security and an aesthetic appeal to any application without compromising on fastener performance, Hafren Fastener offers a new range of 2-Hole security fasteners. They’re an ideal choice for the specifier that wants to “chic up” an application with a design classic.
The 2-Hole fasteners are tamper-resistant with an appealing aesthetic appearance, which is often specified by architects and designers who desire a smooth, sleek, contemporary finish.
The 2-Hole security fasteners are removable and reusable, making them ideal for applications where security is required while allowing access for routine maintenance. Stocked in A2 Stainless Steel, the range offers excellent corrosion resistance in internal or external applications, so they won’t rust.
This drive system, sometimes known as Snake Eye or Pig Nose, is designed for low to medium torque applications. It has two holes drilled into the head which requires a unique 2-pin matching driver to install and remove it.
The 2-Hole security fasteners can be used alongside or instead of standard parts. With a wide range of fasteners available from stock, including:
  • Pan and countersunk-head options
  • Self tappers and machine-screw threads
  • Raised countersunk machine screws (ideal for electrical applications)
Tagged With: hafrenfastener
