    • Subscribe!
THK Launches New Ball Splines
By Design World Staff | November 8, 2006
Schaumburg, IL — With the addition of its Types SLS/SLF, THK combines Caged Technology with its successful ball spline design.
THK Ball Splines
The ball spline is a direct motion system in which the balls embedded in the spline’s external nut can convey torque while making smooth linear motion in the rolling groove of the precisely ground spline shaft. The incorporation of THK Caged Technology, and an optimized design of the ball circulation path, enhances this smooth movement in even vertical applications.
THK Caged Technology employs a synthetic resin cage with a patented curvature that cradles each ball and separates it from the next. The spaces between the rolling elements retain grease and act as a lubrication system for long-term maintenance-free operation. Additional benefits of Caged Technology for the Types SLS/SLF include high-speed operation due to evenly spaced balls, high rigidity equivalent to an LT shaft (±10%) and low noise with the use of a resin circulation path and optimum ball diameter.
Types SLS/SLF are available in spline shaft outer diameters from 15 to 100 mm. They are interchangeable with THK’s Type LBS. Application examples using Type SLS/SLF include inspection machine, medical equipment, wafer transfer, printing machine and pressing machine.
THK manufacturers the widest range of linear motion products including conventional LM guides, ball screws, mechanical actuators and ball splines and more.  All THK products have been designed and manufactured to meet the strictest requirements. THK’s experienced Global Engineering Team can provide customized linear motion solutions with our standard linear motion products as well as our mechatronics products for your most demanding applications.
To learn more, log on to www.thk.com or contact THK America, Inc., 200 E. Commerce Dr., Schaumburg, IL 60173, Phone: (847) 310-1111, Fax: (847) 310-1182, e-mail: [email protected].
Filed Under: Aerospace + defense, Factory automation, Ball screws • lead screws, Bearings, Packaging, Mechanical, Motion control • motor controls
Tagged With: THK
    • Subscribe!
