THK’S New Lightweight LM Guide
By Design World Staff | August 25, 2008
Schaumburg, IL ‚– The new Light LM Guide from THK America, Inc. enables high-speed operation.
Featuring a cold drawn hollow rail and an aluminum block, the Light weighs approximately 40% less than conventional guides (calculated for a 1000 mm rail length with one block). To ensure a long service life, the Light includes the same hardened steel raceways as those used in conventional models. The use of THK Caged Technology in the LM Guide provides smooth movement even during high-speed operation.
THK Caged Technology employs a synthetic resin cage with a patented curvature that cradles each ball and separates it from the next one. The spaces between the rolling elements retain grease and act as a lubrication system for long-term maintenance-free operation.
Lightweight components of the Light LM Guide are dimensionally interchangeable with THK‚’s conventional SSR. Standard blocks can be used on a hollow rail, and aluminum blocks can be used on a conventional rail.
The Light is available in sizes SSR15XW, SSR20XW and SSR25XW.
www.thk.com
Filed Under: LINEAR MOTION, Motion control • motor controls
