Thomas’ 1010 Series Pumps are Reliable and Safe
By Editor | December 13, 2012
Designed for handheld gas and leak detection warning devices, the new 1010 Series diaphragm compressors and pumps from Thomas have been tested for 4,000 hours of nonstop operation providing the utmost in reliability and safety. Compact and lightweight (.03 lbs./.01 kg), the efficient operation and low power consumption of the 1010 Series not only gives the pump and compressor long life, but also extends the battery life of the warning device.
Thomas-Pump
The 1010 Series also features oil-less operation, a sealed air path for contamination-free analysis, and a restart option at low temperatures for use in cold environments. Low inductance level and stall current allow for compliance to intrinsic safety requirements.
Maximum continuous pressure is rated to 8.7 psi/.6 bar, and maximum vacuum to 14.8 inHg/-500 mbar.
Thomas Division
gd-thomas.com
Filed Under: Fluid power, Hydraulic equipment + components, Pumps
Tagged With: Thomas Division
Comments
  1. Robert Buxbaum says
    May 12, 2021 at 5:05 pm
    I need a low power pump to pump 10 ccm of liquid at 1 or 2 psi. Is this one?
Examining direct drive hydraulic maintenance
cylinder
Small, compact cylinder boasts large preload capacity
High modulus plastics for off-highway
Peninsular-Cylinder-top-10-coolest-things
Custom Peninsular Cylinder design named a finalist for “Coolest Thing Made in Michigan”
