Thomas 1510 – The solution pump for liquids
By Editor | July 17, 2015
The fast, the consistent, the safe pump solution
The new diaphragm liquid pump 1510 is designed for fast suction of liquids, even when the medium is mixed with gas. The diaphragm design ensures very consistent flow with minor pulsation. Therefore, the THOMAS 1510 fits perfectly to applications in laboratory equipment and inkjet printing. Flow Rate up to 700 ml/min, Pressure height up to 20 m H2O, and Suction height up to 7 m H2O.
Fast suction of liquid and mixed media
Laboratory instruments equipped with the THOMAS 1510 benefit from higher throughput and reliable test results. The pump empties the vessels very fast and residue-free due to its high suction performance.
Low pulsation for consistent flow
In order to achieve the best printing quality, inkjet printers need a steady delivery of ink to the print head. With its special pump design, the THOMAS 1510 provides consistent flow with little pulsation. In addition it delivers the ink bubble-free to the print head.
thomaspr-150717
Integrated pressure relief valve (optional) for increased safety and different choices of materials
An integrated pressure relief valve avoids overpressures in the system, that might lead to leakage and damages in the machine caused by liquid. Another customizable component of the THOMAS 1510 is especially valuable for the use in industrial inkjet printers that process inks with special additives. For example, inks for ceramic tile printing often include particulate material or chemically aggressive substances. Our THOMAS 1510 diaphragm pump can be customized with abrasion or chemical resistant materials corresponding to special applications.
Thomas
www.thomas1510.com
Filed Under: 3D printing • additive manufacturing • stereolithography
PCB mills
September 2020 Special Edition: 2020 Additive Manufacturing Handbook
The Decision-Makers’ Guide to Additive Manufacturing: Explore the essentials of today’s AM environment and improve your results
Top 3 reasons why you should consider additive manufacturing today for production parts
