Thomas 907Z Series Brushless DC Pump
By Editor | November 9, 2012
The 907Z Series pressure/vacuum oil-less diaphragm pump from Thomas provides the ultimate in mobility with a quiet, efficient lowvibration design that utilizes die-cast aluminum components for durability – all combined with a highly efficient, long-life 24V brushless DC motor.
907Z_gs_1
Specifically designed for fuel cell applications, the 907Z Series also features oil-less operation, stainless steel valves, wetted parts treated for corrosion protection and is RoHS compliant. Maximum continuous pressure is rated to 25 psi (1.72 bar) and maximum vacuum to 21.2 in.Hg (717 mbar).
Thomas Division
www.gd-thomas.com
Filed Under: Fluid power, Pumps
Tagged With: Thomas Division
Next steps in fluid power connections
cylinder
Small, compact cylinder boasts large preload capacity
Clippard Eclipse proportional Valve
Proportional isolation valve offers ultra fine resolution and high repeatability
Fluid power manufacturer receives environmental stewardship recognition
