Thomas Series 2665 Compressor for Air Vending Applications
By Stacy Combest | July 10, 2013
Series 2665 WOB-L Piston Compressors from Thomas are specifically designed to stand up to the rigors of use in air vending or tire inflation systems.
The construction of durable, light weight die-cast aluminum components, epoxy coated wetted parts, thermally protected permanent split capacitor AC motors, specially formulated piston seals, stainless steel valves and permanently lubricated non contact seal bearings, oil-less, non-lube piston and cylinders, twin nine-blade cooling air flow fans make it the preferred compressor for air vending applications.
It is supplied with an ASME safety valve, 1⁄4-18 NPT street elbow and intake filter assembly. Stainless steel wire fan guards are an available option for those systems requiring enhanced safety features.
Thomas_2665
115/60/1 models are rated at 3.68 cfm (104.2 l/min) open flow, 100 psi (7.0 bar) maximum continuous pressure, 120 psi (8.3 bar) maximum intermittent pressure and 100 psi (7.0 bar) maximum pressure restart.
220-240/50/1 models are rated at 3.23 cfm (91.5 l/min) open flow, 100 psi (7.0 bar) maximum continuous pressure, 120 psi (8.3 bar) maximum intermittent pressure and 100 psi (7.0 bar) maximum pressure restart.
For more information on the Series 2665 WOB-L Piston Compressors from Thomas, click here.
Thomas Division
gd-thomas.com
Filed Under: Pneumatic equipment + components
Tagged With: Thomas
