The BWLC (Bellows Clamp) Series coupling specifically addresses higher torque and bore capacities in the area of motion control. The BWLC Series offers the highest amount of torsional stiffness for accuracy and repeatability. The BWLC Series coupling features a corrosion-resistant steel bellow and aluminum or steel hubs.
The BWLC Series also has a torque capacity of up to 1,328 in-lbs, with a maximum bore capacity of 1.574 inches in diameter. The larger size of the BWLC allows for a greater amount of axial misalignment of .020 inches, with low reactionary loading on bearings.
Features
Highest torsional stiffness
Low reactionary loading
No maintenance required
Low inertia
Notes
Nominal torque, torsional stiffness, weight, and moment of inertia are based on minimum bore size.
Various hub diameters available to accommodate different size bore diameters.
Timken
www.timken.com
Filed Under: Coupling Tips
