Tite Seal Hydraulic Hose Protector
By Design World Staff | March 27, 2009
Chicago, Illinois‚—Cofair Products, Inc. introduces the Tite Seal Hydraulic Hose Protector. The new design offers a self-adhering, abrasion resistant wrap. The new product protects all size hoses eliminating the need for stocking multiple size hose protectors.
Also because it‚’s a self-adhering material, it can protect isolated sections of a hose, unlike traditional protectors that require covering the entire hose. The
hydraulic hose protector is composed of neoprene that can stand up to oils, gasoline and solvents. The neoprene composition also allows the ability to bend and flex. The hydraulic hose protector is truly a product for all seasons. It can withstand temperatures ranges from ‚–20 degrees F to 200 degrees F.
Equipment operators know and understand the problems of hose failure. Loss of power is a loss of money. The new hose protector is easy to use and can be applied to any size hose in little time. The hydraulic hose protector can be actually applied while in the field avoiding downtime. Tite Seal Hydraulic Hose Protector is available in 12- and 50-foot. rolls in retail packaging, and 300-foot bulk rolls.
www.cofair.com
Filed Under: Fluid power, Hydraulic equipment + components, Safety systems + components
Examining direct drive hydraulic maintenance
cylinder
Small, compact cylinder boasts large preload capacity
High modulus plastics for off-highway
Peninsular-Cylinder-top-10-coolest-things
Custom Peninsular Cylinder design named a finalist for “Coolest Thing Made in Michigan”
