    • Subscribe!
TMR magnetic sensors optimized for current, position sensing
By rtraiger | June 28, 2022
MultiDimension Technology Co., Ltd. (MDT) has released the TMR2623 linear magnetic field sensor with built-in programmable signal conditioning circuitry. Designed for current sensing, position sensing, and other high-performance industrial magnetic sensor applications, they are factory-calibrated and temperature-compensated to customizable sensitivity and full-scale voltage output levels supporting a wide measurement range up to ±500 Gauss, achieving high uniformity and temperature stability in performance metrics across production volumes with enhanced versatility for a variety of applications under diverse operating conditions.
Key features of TMR2623 include: Excellent temperature stability in -40~125°C, with TCS (temperature-coefficient-sensitivity) under 100PPM/°C, TCO (temperature-coefficient-offset) under 50PPM/°C; Programmable sensitivity in 1~200mV/Gauss and full-scale output voltage, corresponding to a customizable measurement range up to ±500 Gauss; High-frequency response up to 2MHz; Two versions supporting 3.3V/5.0V supply voltage; Compact 3*2*0.75mm DFN package;
Filed Under: Sensor Tips
Tagged With: multidimension
LPPS-36B Series Linear Potentiometer Position Sensor with Rod Ends
Hybrid sensors for connected vehicles
How are wearable systems improving?
Faster than any other IDS industrial camera: uEye Warp10 with 10GigE
    • Subscribe!
