Tompkins’ Metric Compression Hydraulic Adapters
By Frank Tobe | December 12, 2013
Tompkins metric compression adapters ensure strong, reliable, and leak-free connections. With a cutting ring design highly resistant to vibrations, they are perfect for pressue applications and temperatures ranging -40° F to 392° F.
These compression fittings are available with a wide selection of shapes, sizes and port threads to meet your application needs. They are finished in trivalent plating and value priced. They meet or exceed all SAE, ISO and DIN standards.
With the Tompkins Thread Identification Kit for female threads, you get precise identification of both metric and BSP threads.
This portable, compact kit features 14 dual-threaded gauges that allow you to measure 28 thread sizes quickly and accurately. Made from hardened anodized aluminum and labeled with laser-engraved sizes, these gauges are durable yet lightweight and easy-to-read for a fast ID.
And all male thread gauges have internal chamfers to accommodate metric or BSP hose fittings with an inverted flare configuration.
Tompkins also offers a Thread Identification Kit incorporating female-threaded gauges for use in identifying male threads.
Tompkins
www.tompkinsind.com
Mobile Hydraulic Tips
Tagged With: tompkins
Mini machines draw ICUEE crowds
excavator1
Why do cylinders fail on an excavator?
AgfaPhoto
What makes a quality hydraulic component?
A look ahead with JARP Industries’ CEO, Kevin Kraft
