Cables with and without plugs can thus be quickly and safely fed into control cabinets or housings. The tool-less cable management system consists of a handful of modular components: a cable entry frame with an integrated gasket, a two-piece thread and locking adapter plus two-piece locknut to fix it in place, and sealing elements with a range of inlays.
The cables are simply fed through the enclosure opening and cable entry frame. Slit, tapered, and finned sealing elements are then fitted around individual cables or conduits on the inside. The sealing elements are then pushed back to fit tight in the cable entry frame. I-, T-, and +-shaped inlays are available for M40 and larger openings, allowing for insertion of a variety of cable sealing elements as required. The cable entry frame as a whole is fixed in place by attaching a two-part thread and locking adapter to the frame on the outside of the enclosure and attaching a separable locknut on the inside. The special shape of the sealing elements ensures high IP66 ingress protection and strain relief working towards accordance with the DIN EN
62444 standard. The wide range of sealing elements for one or more cables of different shapes and diameters offers high flexibility in creating wiring solutions.
The tool-less system minimizes the effort necessary to change existing connections. Unused entry positions in the frame can be sealed with blanking plugs, which can be easily removed at any time to allow additional cables to be inserted.
Conta-Clip Inc.
www.contaclipinc.com
