    • On the Floor
Top-Loading, Slim-Line, 20mm Coin Cell Holder
By Miles Budimir | August 23, 2019
Keystone Electronics Corp. has introduced a new vertical Mount, Coin Cell Holder that allows for top entry of the popular 2032, 2025 or 2x 2016 lithium batteries. This top-loading holder (Cat. #1074) joins Keystone’s full line of Vertical 20mm Coin Cell holders including Cat. #1065 and Cat. #1067.
Designed to retain cells securely under shock and vibration, this new, “Vibra-Fit” holder features a UL 94V-0 rated housing and tin plated brass contacts providing low contact resistant and simplified thru-hole mounting on PCBs. The narrow profile holder affords a minimal footprint for high-density PCB packages allowing users to stack two 2016 cells on top of each other to achieve 6 volts of power or for single cell 3-volt applications from the same board footprint. Ideal for circuit back-up power, it accepts all major manufacturers’ batteries.
The company’s extensive line of Battery Hardware for SMT and THM applications includes Clips, Holders, Retainers and Straps in a wide variety of configurations and sizes.
A major manufacturer of interconnect components and electronic hardware, Keystone provides application-engineering services for product modifications and special design requirements – all supported by pro-active stamping, machining and assembly capabilities. ISO-9001:2015 certified and RoHS compliant, the company headquarters are located in the USA with offices in Canada, Europe, Australia and Asia. All Keystone products are available from its global distribution network.
Keystone
www.keystone.com
Filed Under: Clamps • locks • latches
Tagged With: keystone, keystoneelectronics
Miles Budimir
    • On the Floor
