Torque Control for Web Tensioning
By Design World Staff | March 19, 2009
Magnetic particle clutches and brakes suit many web-tensioning processes that require adjustable, smooth torque on a clean, dust-free environment. These clutches and brakes used for tension control or torque limiting are electromagnetically actuated and consist of input and output members with a cavity between them.
Within that cavity are very small, magnetized metal particles. Because the particles are contained within the cavity, there are no wear particles as might exist in a friction design clutch or brake. The ability of the magnetic particles to slip against each other eliminates stick-slip behavior, even down to single-digit rpm‚’s.
Warner Electric
www.warnerelectric.com
Filed Under: Brakes • clutches
MagnaShear motor brakes make frequent start/stop cycles on cranes & conveyors maintenance-free
DELLNER BUBENZER debuts innovative and optimal performing disc brake series
MagnaShear motor brakes provide secure, no-maintenance holding brake solution for conveyors
Three torque-limiter options compared (and trip torque explained)
