Toshiba Machine’s Latest TH-A Series of Scara Robots
By Design World Staff | April 18, 2008
Elk Grove Village, IL — Already recognized for high speeds, payloads and repeatability, Toshiba Machine’s TH Series has been upgraded to the TH-A Series of extreme performance Scara Robots. Consisting of three models, the TH650A, the TH850A and the TH1050A, these robots offer a 20 — 30% improvement in cycle time (with higher payloads) compared to previous models.
Standard cycle times are 0.31 sec with a 2 Kg payload for the TH650A, and 0.39 sec with a 5 Kg payload for the TH850A and the TH1050A. X-, Y- and Z-Axis positioning repeatability for all three models is ± 0.01mm., while C-Axis positioning repeatability is ± 0.004°.
The rigid construction and vibration-free performance of the TH-A Series result in a longer robot life. The TH-A Series features a sealed labyrinth structure as standard. Piping positions are flexible, and may easily be changed by the end-user. What’s more, because two harnesses are in the robot arm, it is easy to replace them. Other features of the TH-A Series include lower profiles, reduced noise levels and easy maintenance.
Maximum payload mass for the TH650A is 10.0 Kg and maximum composite speed is 7.52 m/s, while the TH850A and TH1050A can each carry 20.0 Kg (TH850A maximum speed is 8.13 m/s and TH1050A reaches up to 9.15 m/s).
The TH-A Series includes a full-function TS Controller. This highly advanced controller is easy to operate and can control a maximum of five axes simultaneously. It includes a built-in PLC, a multitask function and many more features.
For more information, contact Toshiba Machine Co., America, Control Systems Division, 755 Greenleaf Avenue, Elk Grove Village, IL 60007, Phone: (847) 709-7308, Fax: (847) 709-7358
www.toshiba-machine.com
.: Design World :.
Filed Under: Factory automation, Material handling • converting, Motion control • motor controls, Mechatronics
49503-ACS Motion-CMxa
SDP-SI-040
PACMotion-servos
