The Vert-X 22 Series of touchless magnetic angle sensors feature a permanent magnet secured to the rotating object, so that there is no direct mechanical linkage between the shaft and the measuring system, and therefore no wear.
Key specifications include 0 to 360° measurement range, resolution to 14-bit, repeatability of 0.1° or better, and maximum hysteresis of 0.1°. Eight output options are available: 0.1 to 10 V, 0.5 to 4.5 V, 4 to 20 mA, 10 to 90% of power supply, SSI, PWM, Incremental and SPI. Redundant output versions are offered as well.
Novotechnik U.S., Inc.
www.novotechnik.com/vx22/
Filed Under: SENSORS, TEST & MEASUREMENT
