They say big things come in small packages. The latest product launch from decking giant Trex Company proves this point. Further reinforcing its legacy as the world’s largest manufacturer of wood-alternative decking and railing, is launching a comprehensive collection of Trex-branded deck fasteners and accessories that will begin hitting the market this month.
With more than 120 SKUs, the new Trex Hideaway Fastener Collection includes solutions for every composite deck fastening and finishing need.
Featuring more than 120 SKUs, the new Trex Hideaway Fastener Collection includes solutions for every composite deck fastening and finishing need — from color-matched screws and plugs to specially engineered bits, depth setters and clips — including several first-to-market innovations. The collection was well-researched and expertly engineered to make installation easier and more efficient while delivering a clean, cohesive aesthetic.
The new tools and accessories are fully compatible with all Trex decking products and have also been rigorously tested and proven to work with most decking options.
“This collection is poised to disrupt the industry by establishing Trex as a market leader in the decking hardware category,” said Adam Zambanini, executive VP and COO for Trex. “Adding fasteners and finishing components to our portfolio solidifies Trex as a true and total one-stop supplier for decking, railing, and accessories.”
New products will begin rolling out this month with the introduction of the patent-pending Trex Hideaway Butt Joint Clip. Designed specifically for use where deck boards meet over a single joist, this specialized clip ensures perfect alignment and a strong connection without the hassle of additional joists and fasteners. The extra-wide “wings” of the clip provide the same secure connection as two standard hidden fasteners, so that just one clip is required per side.
Additionally, the clip’s “shoulders” provide the support of two joists, eliminating the need for a sister joist in end-to-end deck board applications and resulting in quicker deck installation without compromising aesthetics.
Next up this spring will be the introduction of Trex Hideaway Deck Plugs and Trex Hideaway Fascia Plugs. These first-to-market collated plugs feature proprietary construction and are made from the same decking shell material, embossing rolls, and pigments used to create Trex decking and fascia. With these specially designed plugs, contractors no longer have to rely on locator tools to ensure safe and effective installation, giving them the ability to conceal fasteners anywhere on the deck.
The rest of the Trex Hideaway Fastener Collection will roll out later this year, including:
- Color-Match Composite Decking and Fascia Screws (patent pending) – Engineered specifically for Trex decks, these fasteners feature ultimate color matches with all Trex decking and fascia lines along with a unique design that delivers optimal stability, increased drive speed and a mushroom-free finish. Screws feature Phillips’ patented HEXSTIX technology for optimal accuracy and STICK-TIGHT technology to guarantee the perfect bit fit with every drive. These screws also resist stripping, rusting, and fading, making them ideal for use on deck borders, breaker boards, picture frames, stairs, and the field of a deck where they blend in with their surroundings to create a harmonious look.
- Counterbore Bits (patent pending) – Durably designed in color-coded options for fastening Trex color-match fascia screws and decking and fascia plugs, these new counterbore bits feature forged spade designs for enhanced durability. An innovative rotating wing on each bit delivers a swift, efficient cut while ensuring material removal to prevent scratching the deck or fascia surface.
- Depth Setters (patent pending) – Specifically engineered and labeled for decking and fascia applications, these depth setters are equipped with the Phillips HEXSTIX Drive System, allowing installers to drill to the correct depth quickly and precisely, every time. Made with high-quality materials, each setter is protected by a glass-filled nylon sheath and rubber bumpers to prevent wear and to avoid marring the deck surface during installation.
- HEXSTIX Drive Bit – Designed for precision, the HEXSTIX HS20 Drive Bit works seamlessly with Trex Hideaway Composite Decking & Fascia Screws, ensuring a stable, wobble-free connection with every use.
In addition to these new fasteners and accessories, Trex will continue to offer its universal starter and fastener clips, router bit, and award-winning Trex Universal Fastener One-Step Installation Tool.
“These new components join our already successful Trex Hideaway Hidden Fasteners to round out the most robust fastening offering of any composite decking brand,” noted Zambanini. “These additions also bring meaningful innovation to what has been a relatively stagnant category, delivering improved performance, durability, and ease of use. They afford greater quality control for installers and give our channel partners a competitive advantage by allowing them to deliver end-to-end solutions from one supplier for a seamless, worry-free deck-building experience from the joists up.”
You may also like:
Filed Under: Fastening + joining, Screws • nuts • bolts • rivets
