Triaxial Isotron® Accelerometer from Meggitt Sensing Systems
By John R. Gyorki | July 1, 2010
San Juan Capistrano, CA – Meggitt Sensing Systems has launched the Endevco® model 35A, the world’s smallest ISOTRON® (IEPE-type) triaxial accelerometer with integral electronics, designed for high-precision vibration measurements in three orthogonal axes on very small objects.
Meggitt-Sensing-Systems_Model_35A
Offering a low impedance output, shear mode construction and weighing just 1.1 grams without cable, the adhesive mounted Endevco® model 35A is designed as a complete measurement package to reduce the unwanted effects of mass loading on more delicate test structures. Sensor output is transmitted through the same wires that supply required 4 mA constant-current power. The model comes pre-installed with both field repairable and factory replaceable fine gage wires (34 AWG) as output leads. Model 35A includes the Endevco® model 3027AM5-120 cable with pigtails at one end to connect to the pre-installed accelerometer wires and three BNC connectors at the other end. A removal tool is also provided.
With its extremely small size, the Endevco® model 35A is ideal for the shock and vibration testing of electronic components and equipment; automotive component vibration monitoring; scale model vibration testing; and biomedical research.
www.meggittsensingsystems.com
Filed Under: Automotive, Electronics • electrical, Sensors (position + other), Shocks + vibration control • gas springs, Test + measurement • test equipment
molex-premo-flex
