Trio’s New MC464 Motion Coordinator
By Design World Staff | October 9, 2008
MC464 provides interface options for traditional servo, stepper and piezo control together with many digital interfaces for current digital servo drives. Increase the flexibility of your equipment with support for up to 64 axes of motion control. Trio‚’s tradition of modular configuration has evolved into convenient clip-on modules allowing the system designer to precisely build the configuration needed for the job.
Redesigned from the ground up the attention to detail is evident. The bright easy to read backlight display makes sure that controller status is easily determined, whilst the single piece metal casting provides an integrated earth chassis to improve noise rejection in the industrial environment.
The MC464 supports programs written in Trio BASIC, allowing a smooth upgrade path from earlier series of Motion Coordinator. In addition; GCODE, HPGL and the standard IEC 61131 languages are supported, with full operation of the IEC 61131 language requiring a software license. I/O expansion is provided via a built-in CAN Bus interface. Further fieldbus networks supporting common factory protocols are supported via the HMS AnyBus‚® adapter module.
Every axis can be programmed to move using linear, circular or helical interpolation, electronic cams and gearboxes. Features include support for merging multiple moves that are typically generated by CAD/CAM software and support is provided for continuously rotating machinery.
The axis expansion modules feature many options for Drive Network interfaces, analogue servo, pulse/direction, absolute or incremental feedback and accurate hardware registration.
Configure the controller functionality and connectivity by attaching up to 7 half-height expansion modules or 3 full-height expansion modules. Each module easily attaches to the controller with a new high density bus connection and a uniquely designed screw integrates the earth planes of all modules and controller together. Trio‚’s feature enable code system for axis activation allows the whole system to be scaled exactly to need.
www.triomotion.com
Filed Under: HMIs • operator interfaces • monitors, Motion control • motor controls
Automation 1 Family and iXC4e
49503-ACS Motion-CMxa
SDP-SI-040
