Larson Electronics has announced the release of a 120 watt telescoping LED work light that produces illumination comparable to a 400 watt metal halide without the high heat, fragile construction, or high energy use.
The WALTP-3XWP400 LED work light on telescoping tripod from Larson Electronics is designed to provide a portable yet powerful lighting solution that can be quickly transported and deployed. This portable tower features a collapsible tripod that extends from three feet to ten feet in height and three LED light heads mounted to a single, removable bracket. This adjustable work light produces 2,924 lumens of bright white light and distributes it in a wide flood pattern capable of illuminating 15,000 square feet of work space. Each light head contains twelve, 3.3 watt LEDs housed within a waterproof aluminum housing that is powder coated for added durability and resistance to corrosion. The lamps have a 50,000+ hour operational life, providing more than twice the longevity of HID lamps, and are designed to provide high output while running cooler, resulting in less heat in the work area and less chance of accidental burns.
This LED light tower is designed to withstand demanding conditions and is waterproof, vapor proof, and built to resist the damaging effects of an outdoor environment. The heavy duty aluminum tripod is durable, lightweight and adjustable to any length between 3.5 feet and 10 feet. The tripod legs collapse and the light head bracket is removable for simple portability and deployment. Power is provided by a 25’ SOOW cord terminated with an optional cord cap to accommodate many plug outlets across the globe. This LED work light can be easily stored and carried in a work truck for rapid deployment as a scene light for first responders to downed lines, main breaks, or accident scenes and other applications where general area lighting is not available.
Larson Electronics specializes in portable industrial lighting equipment, high mast light towers, explosion proof light fixtures, power distribution systems, LED lighting and more. To view their wide range of products, visit them on the web at Larsonelectronics.com or call 1-800-369-6671 for more information.
Larson Electronics will be attending the 2016 OTC show in Houston, Texas from May 2nd to May 5th. Visit them at booth 6716 to inquire about their lighting solutions for many industrial applications.
Larson
larsonelectronics.com
Filed Under: Lights • signal lamps • indicators, Flanges • supports • mounts • brackets, Power Electronic Tips
