Tripod Support Bases from J. W. Winco
By Patrick Curran | July 30, 2010
NEW BERLIN, WI — J. W. Winco, Inc. announced it now offers AN 100 series Tripod Support Bases.
JW-Winco-Tripod_Support_Bases
These RoHS-compliant bases are compatible with both inch and metric components. The support base is black reinforced polyamide. The threaded bushings for leveling feet are nickel-plated brass, and the fasteners are stainless steel.
The tripod support bases are normally used with aluminum, plated steel or stainless steel tubing and either side mounting brackets AN 200 or AN 205, or support bases AN 300 or AN 305, also available from J.W. Winco. A variety of leveling feet or casters that can be used with these tripod support bases are also offered by the company.
J.W. Winco
www.jwwinco.com
Filed Under: Assembly, Fastening + joining • locks • latches • pins, Mechanical
Covered compression latch enhances safety and reduces maintenance errors
Omron D41L hygienic guard locking switch is a tamper-proof solution for ensuring access control and workplace safety
Omron D41G guard lock and handle is an easy-to-wire and intuitive solution for safeguarding machine tools and robotic cells
Omron D41D high-coded non-contact door switch for safeguarding machine tools and robotic cells
