  • Articles
  • 3D CAD Models
    • 2020 Winners
    • 2019 Winners
    • 2020 LEAP Awards
    • DIGITAL ISSUES
      • EE World Digital Issues
    • 2020 LEAP Awards
    • Motion Design Guide Library
    • Suppliers
  • COVID-19
Turbine oil increases the efficiency of hydroelectric plants
By Mike Santora | October 7, 2019
Kluber-Hydropower-PhotoCost pressure, sustainability goals, influences from the market as well as environmental and renaturalization measures force operators of hydroelectric power stations to generate energy even more efficiently and profitably.
This can be done either by reconstructions or by investments in new technology. Minor measures can already make an important difference without incurring high costs.
With the new lubricating oil Klüberoil EE 1-46, Klüber Lubrication has found a sustainable solution for optimizing the efficiency of both existing and new installations.
“The turbine oil was developed in cooperation with a leading European manufacturer of hydroelectric power stations. The reduction of internal friction optimizes the efficiency loss in plain bearings. Klüberoil EE 1-46 complies with the requirements of the DIN 51515-2 standard. The high-performance lubricating oil can be used in all types of hydroelectric power stations, run-of-river power stations, storage power stations, and pumped storage power plants for oil-lubricated turbines and generators,” says Florian Held, global project manager hydropower, Klüber Lubrication.
The expert for specialty lubricants has used a new, unusual approach in developing the new oil. The aim was to manufacture an oil for turbines and generators which increases the efficiency in plain bearings of generators. The semi-synthetic plain bearing oil Klüberoil EE 1-46 can substantially reduce efficiency losses in generator bearings.
The new energy-efficient turbine oil shows a low foaming tendency and high oxidation stability. The use of Klüberoil EE 1-46 optimizes efficiency and extends oil change intervals, increasing the service life of components. Hence, cost savings can be achieved easily and efficiently. Klüberoil EE 1-46 also shows good compatibility with plain bearing materials.
Klüber Lubrication
www.klueber.com
Comments
  1. William K. says
    October 9, 2019 at 6:19 pm
    Certainly improving the efficiency by reducing the friction is a good idea, and I am amazed that nobody did it 50 years ago. Reduced friction leads to reduced heat and too much heat in the bearings is never a good situation.
Tell Us What You Think! Cancel reply
MOTION DESIGN GUIDES
  • With virtual commissioning, commissioning time and prototype waste is reduced
  • Master Bond Supreme 10HT High Strength, NASA Low Outgassing Approved Epoxy
  • Drilling Rig OEM Benefits from a PLC with Edge Computing Technology: IIoT Case Study
  • #1 Reason for Retaining Ring Failure & How to Overcome It
  • Motion controllers: design from scratch or buy ready-made?
Tweets by @DesignWorld
  • Articles
  • 3D CAD Models
    • 2020 Winners
    • 2019 Winners
    • 2020 LEAP Awards
    • DIGITAL ISSUES
    • 2020 LEAP Awards
    • Suppliers
  • COVID-19
