TURCK Absolute Miniature Encoders
By Miles Budimir | September 7, 2010
Minneapolis, MN—TURCK announces that the Kübler by TURCK 2430 shaft and 2440 hollow shaft miniature encoders are now available in absolute versions. The encoders boast a 24 mm diameter housing that makes them ideal for space-restricted areas, with a non-contact design that minimizes wear—delivering exceptional ruggedness in a compact package.
TURCK-Absolute-Miniature-Encoder
Rather than determining encoder position based upon the home position, as incremental varieties do, 2430 and 2440 absolute encoders assign a unique output for each position. With this design, the encoders retain specific position data, even if equipment power is turned off.
All 2430 and 2440 miniature encoders deliver a maximum speed rating of 12,000 RPM, plus an extensive temperature range of -20 to 85º C to suit diverse plant environments. With radial and axial cable outlet options, these compact encoders demonstrate even further applicability in tight spaces.
TURCK
www.turck.us
Filed Under: Factory automation, Encoders • absolute, Motion control • motor controls
49503-ACS Motion-CMxa
SDP-SI-040
PACMotion-servos
