TURCK Enhances Line of Rugged Ethernet Switches
By Dave Miyares | April 5, 2010
Minneapolis, MN — TURCK’s line of rugged, harsh duty Ethernet switches has been updated to include unmanaged models that will support either 4- or 8-pin M12 twisted pair cable, as well as 4- and 5-pin 7/8-16UN power cable. The 4-pin switch is suitable for EtherNet/IP™ applications with both managed and unmanaged options, while the 8-pin switch is suitable for standard Ethernet applications.
TURCK-Harsh-duty-Ethernet-switches
The fully encapsulated switches are capable of information transfer and real-time I/O control in harsh duty locations. The switches support 10/100 Base-T with twisted pair Ethernet cable. The unmanaged switches are available with 5 or 9 ports, while the managed switch is available with 9 ports, one of which is used as a RS-232 configuration port.
Switches are simple to set up by applying power and connecting devices to the ports. A managed switch supports IGMP, RSTP, SNMP and V-LAN and may be configured by the RS-232 serial configuration port or by an internal Web page.
TURCK
www.turck.us
Filed Under: Ethernet — cables • hubs • switches, Networks • connectivity • fieldbuses
MTConnect Institute releases Version 2.0 of the MTConnect Standard
OPC UA
Everything is moving – OPC UA Companion Specification “Global Positioning”
Single common conformance test plan to be available for the IEC/IEEE 60802 TSN profile for industrial automation
Ethernet/IP Network specification complete for Ethernet-Apl physical layer for process automation
