Minneapolis, Minn.‚—TURCK has expanded its 1-1/8 inch minifast‚® connector line to handle even more applications with the addition of the 19-pin connector. The 19-pin minifast connector is rated for up to 300 Volts, 4 Amps per pin, and it is an excellent solution for applications requiring an even more robust, cost-effective solution than a traditional 19-pin M23 connector‚—including material handling in manufacturing and packaging applications.
The 19-pin connector adds to the existing 9, 10 and 12-pin 1-1/8 inch minifast connector line. Additional minifast connector sizes and pin counts are also available, including a 7/8 inch connector with 2 through 6 pins, as well as a 1 inch connector with 6 through 8 pins. All connectors provide IEC IP 68 protection.
Like most TURCK cordsets, the minifast line offers male or female, straight and right angle connectors, standard and custom lengths, and pigtails or extensions. Fully encapsulated mating receptacles with nickel-plated brass housing, as well as 1/2″-14 NPT, 3/4″-14 NPT, PG 16 and M20 mounting threads complete the system.
